Can someone point me in the right direction?
Hi All!
Sorry if this is a bit basic but it will really help me to get moving in the right direction.
I am trying to come to setting up a multiroom system but I simply can not afford the time to run and test a whole multitude of different systems, and anyway, I really WANT to use Volumio!
I have a number of questions:
  1. Is there any way to get around the limit of 6 Volumio devices in a multiroom setup?
  2. If I use Chromcast devices, can I set the volume of them independently of each other?
  3. Can I use RaspiCast?
  4. Can I boot from a network drive?
  5. Is there any way to simply disable certain menus and options to prevent meddling with settings?
  6. I have a Spotify Premium account which i want to stream from to each, any or all of the Volumio devices. Should I be using LMS or is there a plugin which will handle this?
Just thinking a little further on the Multiroom/Chromecast subject; Can you have a multiroom configuration AND cast the output with seperate volume controls to each device?
Thanks in Advance
Matthew
Hello!
Here Davide from Volumio tech support
Please to help you!
A support email has just been sent to your address, please follow up on that for further help
Please also take a look of help.volumio.com for infos, tips and troubleshootings
Thank you!
Best
DAVIDE
VOLUMIO TECH SUPPORT
