I’m very new so I really hate opening a thread, but I just can’t find anything that addresses exactly whats going on.
I have volumio installed fine, it creates a hotspot fine, it accepts my password fine, but then it just doesn’t connect. It tries for a while and basically times out. I’ve tried all the usual turning off phone, reset router and whatnot. I’m not sure what else to try.
Any thoughts? Any advanced settings in the hotspot or something? I’m using android. I could probably connect via ethernet but it’s a pain…
It doesn’t detect the device though. Am I not supposed to connect the app via the generated hotspot? Otherwise wouldn’t the rpi have to know to connect to my wifi, without having been configured? Either way, the app isn’t finding the rpi.
Go into your devices wifi settings and connect to the volumio hotspot.
Once it connects it should use the devices browser and automatically connect to volumio’s setup page
If not open the volumio app and it should find volumio
Yeah that’s what I’m saying, the hotspot is there, I can almost connect, but it hangs and won’t actually connect, despite appearing to be all good to go (accepts password etc…).
The app simply finds nothing when not connected to the hotspot.
Hotspot is there, can’t connect to it.
Seems this isn’t a common issue as I can’t find it happening to anyone else…any troubleshooting ideas?
You shouldnt have to enter any passwords.
Just open the wifi settings, let the phone scan till it finds “Volumio-****” tap on it and it should just conect with the internal browser
I thought it was normal for the volumio hotspot to have a password (volumio2). It works and other passwords don’t (I tried just…for info).
I appreciate the help, I really do, and no offence, but everyone keeps saying to connect to the hotspot and I keep saying I can’t. It hangs. My wifi connection screen in android says “connecting” for a while then gives up and the volumio hotspot goes back into saved connections.
I’ve tried various things like forgetting the volumio hotspot, resetting router, phone, rpi etc…disconnecting from my network…connecting ethernet to rpi and phone to wifi of same network…no matter what the app doesn’t find a connection to configure and my phone’s wifi won’t connect to the hotspot…
Another way… forget using the hotspot, is to connect your RPi via ethernet.
On another computer on the same network type volumio.local into the address bar of an internet browser.
If that fails try entering the RPI’s ethernet IP address into the addres bar, that works too
So, after trying everything I could think of, I redownload and reflashed and everything worked peachy. Was just corrupted somewhere I guess. Always happens the first time eh?
