Raspberry Pi 5, Volumio 3.795.
I used the NanosoundCD plugin on Volumio 2, and it worked well.
Since Volumio 3 does not support the plugin and uses its own CD player instead, I tried the Premium version for its CD-playing feature. It works well except that it cannot retrieve album and track information from an online CDDB service. I asked for help, but it seems the issue hasn’t been fixed.
In the end, I still subscribed to the Premium version of Volumio. The CD player is the main reason I subscribed to it, but the CDDB problem still hasn’t been fixed.
I also tried moOde with its CD player, and it works well, including retrieving track and album information.
https://github.com/coissac/moOdeCDPlayer
https://moodeaudio.org/forum/showthread.php?tid=1765&highlight=cd+player
I don’t know which CDDB server it uses ( MusicBrainz ? ), but it works fine.
You just put the CD in, and it starts playing—very simple, yet effective. Maybe the Volumio team could try fixing the problem by learning from it.
Thank you !
