I installed volumio on Raspberry, it works well for playing music to DAC.www.google.com , without any response. I try apt-get, failed.
Anyone had resolved this problem or know the reason?
thx.
              DNS-probs?
sudo route -n
say?
What about
ping 173.194.39.18
 (= google.com )?
root@volumio:~# route -n
root@volumio:~# ping 173.194.39.18
ping with no respone
              Does your router block your rpi?
No, I only set fixed ip (192.168.1.99) bind to my Raspberry PI in DHCP setting.
 Melomane:
Please post
ifconfig
root@volumio:/usr/bin# ifconfig
lo        Link encap:Local Loopback
              I had solved problem, some one open mac filtering in my router.
