Thank you for your help and good question and yes it is .64 because I am also putting this into the browser and into ssh volumio@192.168.0.64 (ssh’ing in is another problem I have.
LOG 1 Below is my log output. I first deleted the mapping then recreated it. And I did not put in a forward slash.
Then out of curiosity, I put in my root user name and password for my Debian NAS server and the log results are in LOG 2 below.
Now please note that before the server upgrade when it was working I recorded what I was using which is this:
Alias: CD_flac
NAS IP: 192.168.0.6
Path: /mnt/bigdiskc/CD_flac
      /mnt/bigdiskc/JimTunes
Enter steve and password
So I am assuming this is still correct after I upgraded my server and caused this problem?
QUESTION:
When I “Add New Drive” I am not supposed to put in the leading forward slash for the Path:
When I go to edit this drive the forward slash shows up:
So do I need to remove the first forward slash before I save any changes?
LOG 1
Starting Live Log...
  This response was from IP 192.168.0.7, reporting an IP address of 192.168.0.7.
[2022/01/23 15:40:25.626384,  0] ../source3/nmbd/nmbd_namequery.c:109(query_name_response)
  query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.64 for name WORKGROUP<1d>.
info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
info: CoreCommandRouter::executeOnPlugin: networkfs , addShare
info: Adding a new share
info: No correspondence found in configuration for share nfs-CD_flac on IP 192.168.0.6
 volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/mount -t nfs -o ro,soft,noauto 192.168.0.6:/mnt/bigdiskc/CD_flac /mnt/NAS/nfs-CD_flac
info: Error mounting  nfs-CD_flac on IP 192.168.0.6 : exec error Error: Command failed: /usr/bin/sudo /bin/mount -t nfs -o ro,soft,noauto '192.168.0.6:/mnt/bigdiskc/CD_flac' '/mnt/NAS/nfs-CD_flac'
mount.nfs: access denied by server while mounting 192.168.0.6:/mnt/bigdiskc/CD_flac
info: CoreCommandRouter::executeOnPlugin: networkfs , listShares
process exited with code null
LOG2
