do you think all this time we could of just tried the plugin rotation earlier and it would have solved it?
Haha, of course, but in the beginning I had the impression that you don’t have a problem with the touch misaligned to the display but inaccurate touch detection and therefore need the xinput calibration values applied somehow to correct that.
well either gvolt you were a huge help man. I learnt how to use putty, use commands, new terminologies and generally get to grips with learning how do what you showed through this process.
Thank you kindly! I will probably go over it again and just see which part would have worked
Either way i’m sure this will help others who have the same screen and issues.
Well, at least that…
Never change a running system More seriously: If you remove
display_rotate=1
I would expect the Touch Display plugin to rotate not only touch but also the display with the caveat that the misalignment between them would reoccur.
hahaha noted
