I’m trying to calibrate my touchscreen but i cant seem to get any further than this: at the moment the cursor pointer on my screen is mixed up, if i go left it goes down, if i go right it goes up. Also it does not point to where i touch!
permitted by applicable law.
volumio@dark-horse-audio:~$ sudo apt-get install xserver-xorg-input-evdev
Reading package lists… Done
Building dependency tree
Reading state information… Done
xserver-xorg-input-evdev is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 23 not upgraded.
volumio@dark-horse-audio:~$ sudo apt-get install -y xinput-calibrator
xinput-calibrator is already the newest version.
volumio@dark-horse-audio:~$ sudo display
[sudo] password for volumio:
sudo: display: command not found
volumio@dark-horse-audio:~$ sudo diplay=:0.0 xinput_calibrator
Unable to connect to X server
volumio@dark-horse-audio:~$ sudo su display=:0.0 xinput_calibrator
No passwd entry for user ‘display=:0.0’
i either get unable to connect to x server or no passwd entry for user.
i am following this advice:
Calibration of the touch function of displays is beyond the scope of the plugin IMHO. But according to the Waveshare wiki you should be able to calibrate your display with the following steps:
After following the calibration procedure the generated calibration data will be displayed in the terminal. Copy or write down these values and open /etc/X11/xorg.conf.d/99-calibration.conf: sudo nano /etc/X11/xorg.conf.d/99-calibration.conf
Look for the line beginning with Option "Calibration" and subsitute the calibration data with the new values you copied before.
Press the Ctrl+X then Y to save 99-calibration.conf.
Then reboot.
im using the newest version of volumio on my raspberry pi 4 and a 1920x480 touch screen.
volumio@dark-horse-audio:~$ DISPLAY=:0 xinput_calibrator
Calibrating standard Xorg driver “wch.cn USB2IIC_CTP_CONTROL”
current calibration values: min_x=0, max_x=65535 and min_y=0, max_y=6553 5
If these values are estimated wrong, either supply it manually with the --precalib option, or run the ‘get_precalib.sh’ script to automatically get it ( through HAL).
ok that worked but does not allow me to calibrate on the screen?
Do you have the Touch Screen plugin installed? I have very little experience with adding screens to Volumio, but it seems to me that you will need some sort of display manager running to calibrate anything graphically.
Edit: I think I might bow out and let the more experienced offer advice here :).
Yes its all installed and plugged in working, the touch screen works just cant use it as the pointer is all over the place, needs calibrating so it knows where its pointing to when i touch the screen
I decided to reset everything and start again! We finally got there, the calibration screen came up. Now i just need to figure out the next part.
volumio@dark-horse-audio:~$ sudo apt-get install xinput
xinput is already the newest version.
current calibration values: min_x=0, max_x=65535 and min_y=0, max_y=65535
If these values are estimated wrong, either supply it manually with the --precalib option, or run the ‘get_precalib.sh’ script to automatically get it (through HAL).
→ Making the calibration permanent ←
copy the snippet below into ‘/etc/X11/xorg.conf.d/99-calibration.conf’ (/usr/share/X11/xorg.conf.d/ in some distro’s)
Section “InputClass”
Identifier “calibration”
MatchProduct “wch.cn USB2IIC_CTP_CONTROL”
Option “MinX” “8172”
Option “MaxX” “8195”
Option “MinY” “131161”
Option “MaxY” “131525”
Option “SwapXY” “1” # unless it was already set to 1
Option “InvertX” “0” # unless it was already set
Option “InvertY” “0” # unless it was already set
EndSection
MatchProduct “[wch.cn](http://wch.cn) USB2IIC_CTP_CONTROL”
EndSection
