Greetings, since the last update, I have been observing that when I play music from the Bubleunpnp App, and use Volumio as a player, only one track from the playlist is played, does anyone have a solution for this problem? Thank you
I have the same problem, both BubbleUpnp and mConnect via Volumio AV/upnp, freezes after each track.
In Volumio 2.915 they work without any problems.
