Part 1: the hardware. The software, the Grace plugin, the Hymnal device tree overlay and the front panel runtime, follows in its own post.
Why this exists
GRACE started as a need, not a product idea. A faith community I support needed a player that could live in a rack, run all day, feed a broadcast chain over AES/EBU and drive the hall amplifier over balanced analogue, with Volumio inside. Nothing on the shelf did all of that at a sensible price, so I built one. It is a charitable project: the time and the cost are donated.
This is the build diary of the first working 1U prototype, assembled and powered up on 25 October 2026. The design files and the software are private for now; more on that at the end.
Credit where it is due
The heart of GRACE is the Hymnal board, HYMNAL-EBU-V1, and that board is the work of @Darmur. He donated his time and his talent to design and engineer the main PCB: the DAC section, the S/PDIF and AES/EBU section, the power domains, the layout, all of it. The silkscreen reads “Solution by: Just a Nerd / Engineer: Darmur”, and that is the honest split. The concept, the specification, the enclosure, the front panel board and all of the software are mine. The board that makes it sound is his. Thank you, Dario.
Chassis from Modushop. Front and rear panels machined by PCBWay. Everything else designed and built by me.
The four PCBWay panels as they arrived: rear in black with the legends, front in silver with the GRACE marking. One of each is turned over to show the inside face, with the OLED pocket and the connector reliefs.
What it is
A 19-inch, 1U network audio appliance running Volumio on a Raspberry Pi CM5. Rear panel, left to right as you face it:
- ANALOG OUT: balanced XLR left and right, unbalanced RCA left and right
- DIGITAL OUT: TOSLINK optical, AES/EBU on XLR (110 ohm), coaxial S/PDIF on RCA (75 ohm)
- From the carrier: Gigabit LAN, two USB 3 ports, HDMI, external antenna port SMA bulkhead fitted
- Fused and switched IEC mains inlet
Every output carries the same programme at the same time. Play a track and it is on the XLRs, the RCAs, the AES/EBU, the coax and the optical together.
Rear panel with everything mounted. Every aperture is taken from the actual connector position on the Hymnal board and on the carrier.
Compute
Waveshare CM5-IO-BASE-B, NVMe side: Integral M.2 2230 PCIe Gen3 x4 SSD and the CR1220 RTC cell.
The other side: CM5 under its heatsink and fan, Gigabit magjack, USB 3 stack, 40-pin header.
Raspberry Pi CM5 Lite, RAM size, wireless on a Waveshare CM5-IO-BASE-B carrier. Boot and storage on an M.2 2230 NVMe SSD (Integral, PCIe Gen3 x4, 512
GB); the system boots straight from NVMe, no SD card involved. A CR1220 cell keeps the RTC. The CM5 wears a finned heatsink with a fan Waveshare CM5 cooler.
One thing to notice in the chassis photos: the carrier is mounted NVMe side up, so the CM5 and its cooler hang underneath. Reason - the carrier’s connectors land at the right height on the 1U rear panel that way round.
The Hymnal board
HYMNAL-EBU-V1 Rev 1.0, component side. The XLRs, RCAs and TOSLINK are board-mounted, so the rear panel apertures were taken straight from the board, not the other way round.HYMNAL-EBU-V1 Rev 1.0, fabricated at PCBWay. In outline:
- ES9018K2M DAC into OPA1612 output stages, balanced XLR and unbalanced RCA per channel
- WM8804 S/PDIF transmitter driving AES/EBU, coaxial and TOSLINK, transformer-coupled where it matters
- Both converters run on their own local clocks; the CM5’s I2S is fanned out to both, which is why every output is live together
- Separate supply rails per domain: DAC analogue, DAC digital, S/PDIF, SBC, plus a dedicated bipolar supply for the analogue output stages; polyfuse-protected 5.1 V input
- Default mode 32 to 192 kHz with analogue and digital outputs active; an analogue-only mode opens higher rates
- 40-pin header to the carrier, with I2S, I2C and power headers broken out for test
- USB audio out is available from the CM5 as well
Front panel electronics
Surenoo 3.12-inch 256x64 OLED (SSD1322) and my HYMNAL ROTARY/SD1322 V2 board with the encoder fitted.
Back of the rotary board: 40-pin GPIO passthrough, 8-pin power, 4-pin power switch header (switch contacts and ring LED), 16-pin OLED header.
The second custom board is mine: HYMNAL ROTARY/SD1322 V2. It is the hub behind the front panel. The rotary encoder is soldered to it, the OLED plugs into its 16-pin header, the power button lands on a four-pin header (switch contacts plus ring LED), and it passes the 40-pin GPIO and an 8-pin power feed through to the Hymnal board over IDC ribbons. No flying leads to the Pi.
- Display: Surenoo 3.12-inch, 256x64, SSD1322 controller, 16 grey levels, SPI, sitting in a pocket machined into the inside of the front panel; window - bare OLED glass in the pocket
- Encoder: rotary with push, under a 32 mm machined aluminium knob
- Illuminated momentary power button; the ring lights white once the unit is up
Three IDC ribbons do all the front-to-back wiring: 40-pin GPIO, 16-pin OLED, 8-pin power.
Enclosure
Chassis: Modushop Slim Line 1U 170mm depth, black, vented base and lid. It arrives as extrusions, plates and a bag of screws. The only machining I did myself was marking out and drilling the base for the board standoffs. Tools - pencil, centre punch, pillar drill.
Marked out and drilled by hand. Crosshairs in pencil, then drill. Not glamorous, but it is the step that decides whether the rear panel lines up.
Panels: I drew the front and the rear and had them machined by PCBWay; files submitted, DXF and STEP, and it took over 2 weeks to deliver. Front: silver anodised aluminium, 4 mm, with EIA rack slots, the OLED window with its pocket on the inside, a recessed bore for the encoder and the hole for the power button; GRACE silkscreened. Rear: black anodised, 3 mm, with every aperture taken straight from the Hymnal and carrier connector positions, legends silkscreened, and the IEC cutout. Modushop reviewed the drawings for feasibility early on (internal radii on thin stock, thin sections between the XLR cutouts) and that advice carried over to what PCBWay machined.
*First test fit of the rear panel over the Hymnal board and the carrier. Everything lined up first time.
Power and mains
Fused, switched IEC C14 inlet with the illuminated rocker and a spare fuse in the drawer.
Mean Well EPS-65-5-C, an enclosed 5 V 11 A supply. Reason for 11 A - headroom for the CM5, NVMe, cooler and the Hymnal rails with margin to spare. Fused and switched IEC C14 inlet with an illuminated rocker and a spare fuse in the drawer 8A. Mains earth is bonded to the chassis on PSU safety ring screw. The PSU output goes to the Hymnal’s 5.1 V input and the carrier is powered from the Hymnal over the 40-pin header.
Assembly
Everything in: inlet and PSU on the left, carrier in the middle (NVMe up), Hymnal on the right. The Mean Well label is readable here.
Front panel wired: rotary board on the back of the OLED, two ribbons to the Hymnal, four-core lead to the power button.
The whole thing went together in a day, which says more about the panel drawings than about me. Order of work: test fit the rear panel over the boards, mark out and drill the base, mount the PSU and the inlet, mount the carrier and the Hymnal behind the rear panel, build up the front panel with the OLED, the rotary board, the encoder and the button, run the ribbons, close the lid.
First power on
First power on. Green ring, greeting on the OLED.
Flick the rocker, press the button, the ring goes green and the greeting comes up. First track through it: U2, I Will Follow, at 96 kHz to all analogue and digital outputs.
Didn’t like green, changed.
Volumio now playing on the OLED: transport state, volume, sample rate and depth, IP address, title, artist, album, elapsed time and a progress bar.
Knob on, lid on, playing.
Status
Hymnal Rev 1.0 and the front panel board Rev 2.0 are built and under test on this unit. Verified so far: playback on the AES/EBU, coaxial, optical and analogue outputs, both volume modes, the DAC controls, the panel’s greeting, playing screen and brightness policy, and the encoder. The power button is wired; its software integration is in progress. Not yet suitable for manufacture.
Design files and software are private for now. This is a build diary, not a release. The next post covers the software: the Grace plugin, the Hymnal device tree overlay that gives the card its identity on the stock in-tree driver, and the front panel runtime that drives the OLED and the encoder.
The 2U variant with the 7.9-inch touch display is in workings.
Credits
- Concept, specification, enclosure design, front panel board, software: foonerd (Just a Nerd)
- Hymnal main PCB design and engineering, donated: @Darmur
- Chassis: Modushop
- Front and rear panel machining: PCBWay
- Hymnal PCB fabrication: PCBWay
