Hi there
I just did a new install using the above build and I can’t see any plug ins to install?
Using the Intel version of volumio
Cheers
Malcolm
Hi there
Cheers
Malcolm
Thanks for reporting. It was an issue with the plugin repository (which had a major rework last week).
Now its solved and you will be able to see plugins again.
After a build is done, I think there are some smoke test that are executed ? One of them I guess is the plugins?
Thanks.
Just flashed latest image on RPi0w, I can confirm plugins are fine now
Nothing to do with Volumio versions, just the server side volumio plugins.
The issue affected only x86
