Volumio Version: 2.873
Hardware: raspberry pi 4 + remote xiaomi for tv box
DAC: smsl sanskrit 10th mkii
Please!!! I have a problem … since installing ir remote plugin update 1.4.0, the remote does not work on reboot until I disable it and then manually re-enable it from the plugins menu. can anyone help me with this bug?
permitted by applicable law.
volumio@volumio:~$ sudo journalctl -f --no-tail | grep ir_controller
Mar 09 20:18:34 volumio volumio[885]: info: Loading plugin “ir_controller”…
Mar 09 20:18:34 volumio volumio[885]: info: Applying required configuration parameters for plugin ir_controller
Mar 09 20:20:00 volumio volumio[885]: info: ir_controller: File permissions successfully set on /etc/lirc/.
Mar 09 20:20:00 volumio volumio[885]: info: ir_controller: LIRC correctly updated.
Mar 09 20:20:00 volumio volumio[885]: info: ir_controller: HAT did not load /proc/device-tree/ir_receiver!
Mar 09 20:20:01 volumio volumio[885]: info: ir_controller: Raspberry Pi revision code: c03112
Mar 09 20:20:01 volumio volumio[885]: info: ir_controller: Overlay gpio-ir gpio_pin=18 gpio_pull=up loaded.
Mar 09 20:20:01 volumio volumio[885]: info: ir_controller: systemctl restart lirc.service succeeded.
Mar 09 20:20:02 volumio volumio[885]: info: ir_controller: systemctl restart lirc.service succeeded.
I have just finished doing a clean reinstallation of volumio and the plugin but also this time the plugin works after the first installation, but not after the system reboot; thanks if you can help me !!!
great thanks ! I installed Volumio just to be able to use the remote control due to a particular situation. p.s. excuse the ignorance but what is a PR? do you think it will take a long time to solve? Thanks again !!!
PR = pull request on GitHub from which the new plugin version can be built and made publicly available (through plugins management).
No, I will do the PR tonight or maybe tomorrow. balbuze regularly checks new PRs and - if they look OK - merges them. This happens mostly in a few days.
