i added an NFS share with the GUI and the shared music files were discovered just fine. The problem is that after the next reboot the folder /mnt/NAS/server is just empty, and “# mount” does not list the NFS share. Playback of the relevant files doesn’t work.
After mounting the share manually with
mount -t nfs ipadress:/folder /mnt/NAS/server
everything worked fine.
I couldn’t find anything in the fstab, so i added the mount there. I’m going to check if the fstab entry works after the next reboot.
Did anyone else have this problem? It looks like a bug to me, that the added NFS shares are not mounted.
Or are we supposed to add NFS shares manually to fstab?
For a while I couldn’t get my NAS to mount either, but I wrote up my solution and they very kindly turned it into a guide. My guess is you need to get into your NAS and export the file system as described here:
Appending an entry for the nfs share to fstab did the trick:
ipaddress:/music /mnt/NAS/server nfs defaults 0 0
On a side note, NEVER hit the update library button unless you are 100% sure that the nfs share is mounted, or your library is lost, and on the next update mpd needs to read everything from nfs again, which can take hours…
EDIT: I consider this a workaround, and not a solution, because it can only be done over ssh, not in the webinterface.
