Another little one: when I accidentally delete something from the playlist without first stopping playback, connection with Volumio is lost until reboot.
Raspberry connected through wired LAN, laptop through Wifi (other network connections from laptop continue to work ok).
Hello
This problem I have found with wired Ethernet.
Even I once had a case where Volumio was no longer viable. I had to re-flash and configure Volumio the new SD-Card.
I have also found that these problems occur when too fast Playlists are successively deleted.
With the Adroid App MP-Droid this error has not occurred.
