When playing on the system with both apps, after 2 or 3 songs, the playback stopps.
It does not matter if the source is on my minimserver or local on my smartphone.
As the volume keys at the smartphone cannot control the volume, I want to use the playback with the above mentioned apps.
As it is a new system, I think to return it, if not working.
If you have used BubbleUPNP previously with older Volumio version or other systems please try to uninstall BubbleUPNP from Android device first and then install again. It solved all issues (HW volume buttons, album art, duration etc.) in my Samsung S20.
Since you have the Primo Hifi-edition you have the right to get dedicated support from Volumio, but you have to create a support ticket at Jira Service Management
Limitation here, no gapless is possible.
Bubble UPNP is still not working.
Iβm frustrated, Iβm not sure if I bought my needed device.
In opposite to here mentioned other Apps donβt work proper, look for OpenHomeOhMedia-Support!
@ mminga
I experience the same problems as you did 8 months ago.
Can you send me a detailed instruction on how to delete the firmware with Raspbian. Sounds risky to me. Can you use BubbleUPNP with the Volumio Primo in full strength now? (volume control, sorting playlists and albums alphabetically on artist name, displaying album covers etc.).??
I would appreciate your reply.
