I’ve Volumio running on a RPI 4 and reading music from a Synology NAS with Minimserver running on it.
Minimserver allows me browsing music filtered by “quality” or “format” (flac, mp3 or ogg) that I prefer, but the problem is that Volumio is displaying only few results (i.e. after applying filter, 5760 songs, but Volumio displays only songs starting with …up to letter C) in respect to the total of the music available after applying filter. There is a limit in displaying results? I don’t think so!
Any help?
no one with the same problem?
no one with an answer or suggestion?
Have you tried reinstalling MinimServer on the Synology?
MinimServer Downloads
Miminserver seems to work properly: If I use a different app like HiFi Cast I can browse the entire group of songs filtered. In this way I can send music through HiFi Cast to Volumio and play it, without the limitation in browsing.
You could try turning DLNA browser off and back on in Volumio / sources.
That helps if Volumio does not show my DLNA servers.
I’ll try.
Nothing change
