Broadcast sound from volumio to various players
I have volumio installed on a RPi & on a cubox. From now, they have different playlists. I was wondering if it was possible to play the music of one volumio to the other.
In extension, could I be able to broadcast the music of one volumio to a Upnp/DLNA ampli?
I was wondering if volumio could broadcast like a web radio on my local network or something like that. I think that is possible with Upnp/DLNA but I am not sure.
Any advise would be appreciated.
yanndan
Currently there is nothing build in to Volumio that can easily control an other Volumio installation. You might be able to do it with mpc and connect to a remote system.
On the settings page there is a upnp/dlna setting that might help Volumio becomes a host so your other device can access the music using those protocols. Or to share music you could setup one device as a nas for the other and vice versa
Thanks for your answer. After reading it, I found this post https://volumio.org/forum/adding-web-streaming-volumio-t1251.html which seems to be relevant to my question of having the same music broadcasted into my whole flat.
I will try it next week and see if it works for me.
Kind regards,
yanndan
