i have a touchscreen installed…when booting, the background is black, then the volumio logo is displayed, turns black again…and then turns completely white once for 2-3 seconds; then the volumio interface is displayed
does anyone else have the same behaviour with the white screen on boot?
If I recall correctly, this is not related to the application but to the OS in combination with Chromium.
I see this with Volumio but also with the original Raspberry Image (with LMS + Kiosk). just before the display loads the GUI the screen blanks (white) then the GUI loads.
exactly, about 3-4 sec before the GUI
then i’ll do a bit of searching on the net, if it doesn’t only occur under volumio, some people should have something to report about it
I remember, on my old Pi4 with Waveshare 11.9 and Volumio on old version with old kernel after booting was big VOLUMIO on screen. It was in time when I config my LCD format and rotation in “userconfig.txt”. Now it looks as all LCD screen config are load later, with Touchscreen and it’s reason why you don’t see “VOLUMIO” on start and have white screen.
