Hey there
Simple question really I am booting Volumio from my PC x86 got as far as Volumio/Volumio login the logo pops up - now it’s asking for a command - what do I put in ??
you should not landing on the terminal, the x86 image should boot to the web interface
So I’m not running it from an SD Card ? I thought you have to boot from Bios, select which drive, then boot from the selected drive which is the SD Card
So at the bottom of the the page it is asking for a command … I need to know what command or instruction to put in to access the UI
Downloading the Volumio file again , making sure I flash the img file to the SD card hopefully that will do the trick
AFAIK Asus EEE needed a specific graphics driver and resolution settings, so Volumio UI on Asus EEE will not be supported.
Perhaps Volumio will run fine headless, otherwise you’re out of luck I’m afraid.
Thank you very much for the input everyone !!
if things went well, you could reach the graphic interface from any other device in your lan at the address http://volumio.local (or http://<IP_OF_ASUS_EEE>).
but sometimes things don’t go fine: see this post:
X86 Hardware issues (WiFi, DAC, Disks, Boot etc.) - #245 by fo02667
in my case, my pc had not enough hardware resources to let the things go fine:
https://community.volumio.com/t/re-x86-hardware-issues-wifi-dac-disks-boot-etc/55915
