Boot USB Key
My USB key is 32Go.
I try to install Volumio with the image Volumio :mrgreen:
I boot on the key… It’s run… :bulb:
What is the log : volumio/ volumio or root/volumio :question:
When I logged in root, there’s no Volumio Start . Is it normal ?
Thank you for your ansers.
Salut !
Once again, you don’t have to login in volumio to use. If you use a raspberry, you don’t need a screen or a keyboard. You access your device from a other device on the same network (computer, smart). Have a look here : https://volumio.github.io/docs/User_Manual/Quick_Start_Guide.html
With a x86 you have access to volumio webUi directly if you have a screen or access from a other device.
