Mi Raspberry with Volumio is working really well with no flaws, the only thing I noticed is long boot time.
From the moment I plug power in to the first connection with GUI takes almost 4 to 5 minutes.
Is this normal?
Accessing with SSH is possible about two minutes early.
Anyone experienced this? Is there any way to reduce boot time?
Hi, are you able to connect a monitor if only for troubleshooting purposes - this will probably give a good indication of what is “hanging” during boot-up.
Are you using wi-fi by any chance? If so then disable the ethernet port as the system will spend quite some time trying to establish a connection before giving up and then moving on to the wi-fi connection…
yes I could suggest to review the following solution as a potential standard for the new Volumio2.
As of the question, yes, I am still on 1.55, and sure, this is a raspbian issue, not a volumio issue.
I did what was suggested, and that’s exactly what I need. Changing the line to “allow-hotplug eth0” will abort the configuration of the ethernet interface when no cable is plugged.
What would you wanna wait for if link is not up…
