boot problem RaspB+/HifiBerry
Hi
I’ve just flashed microSD card with Volumio 1.51 and powered up hifiberry. I see the leds blinking but the display connected to the RaspB+ stays blank.
I’ve tried with a hifiberry sample image (hifiberry.com/guides/sd-card-images/) and it worked. I don’t know what to do. Any hint?
regards,
Gianpaolo
try to boot Volumio without Hifiberry.
If this works you can configure Volumio. After that you can try it with connected Hifiberry.
hi Joda, thanks for the reply
got it! everything was ok, just my fault: i wAS waiting for a login screen on the display attached to the rasp, while
instead i could already connect through the wifi and open volumio.local
now the problem is:
no sound at all :slight_smile:
