Hi everyone,
I am new on this forum, so please excuse me if I do something wrong.
I am the owner of a Raspberry 3 which is working fine with a competitor software (which I will not name here).
I have seen your wonderful work on volumio project.
I have seen it working fine in a friend of mine.
So I have downloaded volumio-2.348-2017-12-22-pi.img for Raspberry and install it to a micro card.
System is booting well, but it is stuck on login prompt.
I have let system working for more than 1 hour, but no improvement (except screensaver).
If I connect USB keyboard, I can connect to the system.
ls command show me nothing.
I have tried to download image again and checked MD5, but no improvement.
Have you already seen this bug, and do you know how to fix it.
I have also in installed the latest image but haven’t had that issue.
firstly why would need to go to the command prompt. The setup is to be done via the local webpage.
The required wifi password for the volumio access point is volumio2. After which you’re supposed to set up your Dac ( reboot later), then setup Wifi (reboot I think), and then log your phone/laptop to the wifi your Volumio was registered newly. and then install the volumio app on the phone… if iPhone then its available and it works fine.
