Boot problem on Raspberry model B
My name is Cor van Zundert and I am a member of an Audioclub in the Netherlands and thinking about giving a workshop about Audio and PC’s.
My Raspberry does not boot from the new Volumio code, maybe as a result of the newest chipset I have ???
The only thing I see is the power on light.
The (modified) Raspyfi code did work before …
These are the files I see on the SD card:
21-12-2013 12:53 25.244 ubnkern
14-12-2013 02:31 1.887.436.800 ubninit
21-12-2013 12:55 155 syslinux.cfg
21-12-2013 12:55 60.928 menu.c32
If anyone has a hint for me, it would be more than welcome …
Thanks in advance !
Cor van Zundert,
The Netherlands.
Please post in the appropriate section…
Anyway, Volumio features a fix for the new Pi’s. I really think you need to reflash your SD Card, or use another one… Let me know
Hi Michelangelo,
I tried several cards, but without success.
I also used a SD card that has been working on Raspyfi before …
Regards, Cor.
I have two raspberry, the first with the old ram and one with the ram of the new type.
The distribution is working only with the new ram, the problem seems to be the opposite of what was happening with RaspyFi :exclamation:
Leopoldo
