Hello all,
I play around with volumio since two weeks and every time I got a Boot Loop after a few days. The Boot Log shows no Error, but the volumio Log shows the following:
[spoiler]2017-08-24T16:34:58.060Z - info: Cannot mount NAS Diskstation at system boot, trial number 2 ,retrying in 5 seconds
2017-08-24T16:34:58.451Z - info: Data script executed
2017-08-24T16:34:58.494Z - info: MPD running with PID628 ,establishing connection
2017-08-24T16:34:58.520Z - info: Setting Device type: Raspberry PI
2017-08-24T16:34:58.940Z - info: [1503592498938] VolumeController:: Volume=undefined Mute =undefined
2017-08-24T16:34:58.947Z - info: [1503592498945] CoreStateMachine::pushState
2017-08-24T16:34:58.953Z - info: [1503592498951] CoreStateMachine::getState
2017-08-24T16:34:58.956Z - info: [1503592498955] CorePlayQueue::getTrack 0
2017-08-24T16:34:58.961Z - info: CoreCommandRouter::volumioPushState
2017-08-24T16:34:58.963Z - info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
2017-08-24T16:34:58.976Z - info: [1503592498972] interfaceApi::pushState
2017-08-24T16:34:58.979Z - info: [1503592498978] InterfaceWebUI::pushState
2017-08-24T16:34:59.357Z - info: Reloading queue from file
2017-08-24T16:34:59.440Z - info:
2017-08-24T16:34:59.562Z - info: [1503592499561] CoreStateMachine::setRepeat null single undefined
2017-08-24T16:34:59.565Z - info: [1503592499562] CoreStateMachine::pushState
2017-08-24T16:34:59.566Z - info: [1503592499565] CoreStateMachine::getState
2017-08-24T16:34:59.568Z - info: [1503592499567] CorePlayQueue::getTrack 0
2017-08-24T16:34:59.570Z - info: CoreCommandRouter::volumioPushState
2017-08-24T16:34:59.571Z - info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
2017-08-24T16:34:59.576Z - info: [1503592499575] interfaceApi::pushState
2017-08-24T16:34:59.578Z - info: [1503592499577] InterfaceWebUI::pushState
2017-08-24T16:34:59.585Z - info: [1503592499584] CoreStateMachine::setRandom null
2017-08-24T16:34:59.588Z - info: [1503592499585] CoreStateMachine::pushState
2017-08-24T16:34:59.589Z - info: [1503592499588] CoreStateMachine::getState
2017-08-24T16:34:59.591Z - info: [1503592499590] CorePlayQueue::getTrack 0
2017-08-24T16:34:59.593Z - info: CoreCommandRouter::volumioPushState
2017-08-24T16:34:59.594Z - info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
2017-08-24T16:34:59.597Z - info: [1503592499596] interfaceApi::pushState
2017-08-24T16:34:59.599Z - info: [1503592499598] InterfaceWebUI::pushState
2017-08-24T16:34:59.767Z - info: Pushing Favourites {"service":"mpd","uri":"","favourite":false}
2017-08-24T16:34:59.781Z - info: mDNS: Found device Volumiolounge
2017-08-24T16:35:00.080Z - info: Volumio called home
2017-08-24T16:35:00.175Z - info: [1503592500170] Shairport-Sync Started
2017-08-24T16:35:00.250Z - info: Pushing Favourites {"service":"webradio","uri":"http://streams.fluxfm.de/xjazz/mp3-320/audio/play.m3u","favourite":false}
2017-08-24T16:35:00.257Z - info: Pushing Favourites {"service":"webradio","uri":"http://streams.fluxfm.de/xjazz/mp3-320/audio/play.m3u","favourite":false}
2017-08-24T16:35:01.312Z - info: CoreCommandRouter::volumioGetState
2017-08-24T16:35:01.314Z - info: [1503592501313] CoreStateMachine::getState
2017-08-24T16:35:01.315Z - info: [1503592501314] CorePlayQueue::getTrack 0
2017-08-24T16:35:01.317Z - info:
[1503592501316] ---------------------------- Client requests Volumio state
2017-08-24T16:35:01.321Z - info: [1503592501320] InterfaceWebUI::pushState
2017-08-24T16:35:01.382Z - info: [1503592501381] ------------------------------ 70ms
2017-08-24T16:35:02.176Z - info: Upmpdcli Daemon Started
2017-08-24T16:35:03.069Z - info: Cannot mount NAS Diskstation at system boot, trial number 3 ,retrying in 5 seconds[/spoiler]
The device is conncted to the Network and i can access via SSH. Is there anybody can help me to get volumio runs stable?
Thank you and best regards!
Plus
Try removing your NAS drive & re-adding it.
P.S. What is the device and Volumio version?
Wow, that is a fast answer!
It is a Raspberry Pi 2 with IQAudio DAC board and the latest Version of volumio. Can i re-add the NAS via SSH?
Try via the UI and see if it sorts the problem… if not, we’ll go from there.
Thank you so far.
It’s not possible to disconnect the NAS via the volumio GUI. It’s shown only for one second.
I flashed a backup without NAS and volumio started. After adding the NAS the reboot ends in a boot loop.
I tried the same with a second raspberry and the same behavior is shown.
Do you have any idea how to solve this?
Thank you,
Plus
Can you post the settings you have used to add your NAS please?
Hey,
thanks again. I am very impressed of the fast support in this forum!
Settings:
Static IP via Fritz Box
nfc Access to music-folder via Synology Diskstation
Alias: Diskstation
Mounted: Yes
IP: 192.168.178.34
Pfad: /volume1/music/
Typ: nfs
User: admin
Passwort: **************
This configuration works fine, scans the NAS and finds all music. Just after a reboot the rom stucks into a boot loop.
Please do
sudo journalctl -f
and you should see when Volumio restarts, please paste here the most logs you can around that point
shure, here is the log from sudo journalctl -f. I pasted the part which cames over and over again :
Aug 26 17:06:53 volumiolounge volumio[1251]: info: -------------------------------------------
Aug 26 17:06:53 volumiolounge volumio[1251]: info: ----- Volumio2 ----
Aug 26 17:06:53 volumiolounge volumio[1251]: info: ----- System startup ----
Aug 26 17:06:53 volumiolounge volumio[1251]: info: Plugin folders cleanup
Aug 26 17:06:53 volumiolounge volumio[1251]: info: Scanning into folder /volumio/app/plugins/
Aug 26 17:06:53 volumiolounge volumio[1251]: info: Scanning category audio_interface
Aug 26 17:06:53 volumiolounge volumio[1251]: info: Scanning category miscellanea
Aug 26 17:06:53 volumiolounge volumio[1251]: info: Scanning category music_service
Aug 26 17:06:53 volumiolounge volumio[1251]: info: Scanning category plugins.json
Aug 26 17:06:53 volumiolounge volumio[1251]: info: Scanning category system_controller
Aug 26 17:06:53 volumiolounge volumio[1251]: info: Scanning category user_interface
Aug 26 17:06:53 volumiolounge volumio[1251]: info: Scanning into folder /data/plugins/
Aug 26 17:06:53 volumiolounge volumio[1251]: info: Plugin folders cleanup completed
Aug 26 17:06:53 volumiolounge volumio[1251]: info: Loading plugins from folder /volumio/app/plugins/
Aug 26 17:06:53 volumiolounge volumio[1251]: info: Loading plugins from folder /data/plugins/
Aug 26 17:06:53 volumiolounge volumio[1251]: info: Loading plugin "system"...
Aug 26 17:06:53 volumiolounge volumio[1251]: info: Loading plugin "appearance"...
Aug 26 17:06:56 volumiolounge volumio[1251]: info: Loading plugin "network"...
Aug 26 17:06:56 volumiolounge volumio[1251]: info: Loading plugin "services"...
Aug 26 17:06:56 volumiolounge volumio[1251]: info: Loading plugin "alsa_controller"...
Aug 26 17:06:56 volumiolounge volumio[1251]: info: Loading plugin "volumio_command_line_client"...
Aug 26 17:06:56 volumiolounge volumio[1251]: info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
Aug 26 17:06:56 volumiolounge volumio[1251]: info: Loading plugin "upnp"...
Aug 26 17:06:56 volumiolounge volumio[1251]: info: [1503767216533] Starting Upmpd Daemon
Aug 26 17:06:56 volumiolounge volumio[1251]: info: CoreCommandRouter::executeOnPlugin: system , registerCallback
Aug 26 17:06:56 volumiolounge volumio[1251]: info: Loading plugin "mpd"...
Aug 26 17:06:56 volumiolounge volumio[1251]: info: Plugin upnp_browser is not enabled
Aug 26 17:06:56 volumiolounge volumio[1251]: info: Loading plugin "networkfs"...
Aug 26 17:06:56 volumiolounge volumio[1251]: info: Cannot mount NAS Diskstation at system boot, trial number 1 ,retrying in 5 seconds
Aug 26 17:06:56 volumiolounge volumio[1251]: info: Loading plugin "alarm-clock"...
Aug 26 17:06:57 volumiolounge volumio[1251]: info: Loading plugin "airplay_emulation"...
Aug 26 17:06:57 volumiolounge volumio[1251]: info: [1503767217194] Starting Shairport Sync
Aug 26 17:06:57 volumiolounge volumio[1251]: info: Loading plugin "last_100"...
Aug 26 17:06:57 volumiolounge volumio[1251]: info: Loading plugin "webradio"...
Aug 26 17:06:57 volumiolounge volumio[1251]: info: Loading plugin "i2s_dacs"...
Aug 26 17:06:57 volumiolounge volumio[1251]: info: CoreCommandRouter::executeOnPlugin: system , getConfigParam
Aug 26 17:06:57 volumiolounge volumio[1251]: info: Executing start script for DAC IQaudIO DAC Plus
Aug 26 17:06:57 volumiolounge volumio[1251]: info: Loading plugin "my_volumio"...
Aug 26 17:06:57 volumiolounge volumio[1251]: info: Loading plugin "volumiodiscovery"...
Aug 26 17:06:58 volumiolounge volumio[1251]: *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
Aug 26 17:06:58 volumiolounge node[1251]: *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
Aug 26 17:06:58 volumiolounge node[1251]: *** WARNING *** Please fix your application to use the native API of Avahi!
Aug 26 17:06:58 volumiolounge node[1251]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
Aug 26 17:06:58 volumiolounge node[1251]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
Aug 26 17:06:58 volumiolounge node[1251]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister>
Aug 26 17:06:58 volumiolounge volumio[1251]: *** WARNING *** Please fix your application to use the native API of Avahi!
Aug 26 17:06:58 volumiolounge volumio[1251]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
Aug 26 17:06:58 volumiolounge volumio[1251]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
Aug 26 17:06:58 volumiolounge volumio[1251]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister>
Aug 26 17:06:58 volumiolounge volumio[1251]: info: Applying required configuration parameters for plugin volumiodiscovery
Aug 26 17:06:58 volumiolounge volumio[1251]: Discovery: StartAdv! undefined
Aug 26 17:06:58 volumiolounge volumio[1251]: Discovery: Started advertising... Volumiolounge - undefined
Aug 26 17:06:58 volumiolounge volumio[1251]: info: CoreCommandRouter::executeOnPlugin: system , registerCallback
Aug 26 17:06:58 volumiolounge volumio[1251]: info: Loading plugin "auto_play"...
Aug 26 17:06:58 volumiolounge volumio[1251]: info: ControllerAutoPlay - connecting mpd on host: localhost; port: 6600
Aug 26 17:06:58 volumiolounge volumio[1251]: info: Loading plugin "youtube"...
Aug 26 17:07:01 volumiolounge volumio[1251]: info: Loading plugin "albumart"...
Aug 26 17:07:01 volumiolounge volumio[1251]: info: Plugin example_plugin is not enabled
Aug 26 17:07:01 volumiolounge volumio[1251]: info: Loading plugin "updater_comm"...
Aug 26 17:07:01 volumiolounge volumio[1251]: info: Plugin mpdemulation is not enabled
Aug 26 17:07:01 volumiolounge volumio[1251]: info: Loading plugin "rest_api"...
Aug 26 17:07:01 volumiolounge volumio[1251]: info: Loading plugin "websocket"...
Aug 26 17:07:02 volumiolounge volumio[1251]: info: ___________ START PLUGINS ___________
Aug 26 17:07:02 volumiolounge volumio[1251]: info: PLUGIN START: appearance
Aug 26 17:07:02 volumiolounge volumio[1251]: info: PLUGIN START: last_100
Aug 26 17:07:02 volumiolounge volumio[1251]: info: CoreCommandRouter::volumioAddToBrowseSources[object Object]
Aug 26 17:07:02 volumiolounge volumio[1251]: info: [1503767222118] CoreMusicLibrary::Adding element Last_100
Aug 26 17:07:02 volumiolounge volumio[1251]: info: PLUGIN START: webradio
Aug 26 17:07:02 volumiolounge volumio[1251]: info: [1503767222147] CoreMusicLibrary::Adding element Webradio
Aug 26 17:07:02 volumiolounge volumio[1251]: info: PLUGIN START: my_volumio
Aug 26 17:07:02 volumiolounge volumio[1251]: info: PLUGIN START: auto_play
Aug 26 17:07:02 volumiolounge volumio[1251]: info: PLUGIN START: youtube
Aug 26 17:07:02 volumiolounge volumio[1251]: info: Youtube::onStart Adding to browse sources
Aug 26 17:07:02 volumiolounge volumio[1251]: info: [1503767222171] CoreMusicLibrary::Adding element Youtube
Aug 26 17:07:02 volumiolounge volumio[1251]: info: Loading i18n strings for locale de
Aug 26 17:07:02 volumiolounge volumio[1251]: Updating browse sources language
Aug 26 17:07:02 volumiolounge volumio[1251]: Cannot find translation for sourceYoutube
Aug 26 17:07:02 volumiolounge volumio[1251]: info: CoreCommandRouter::executeOnPlugin: mpd , getConfigParam
Aug 26 17:07:02 volumiolounge volumio[1251]: info: CoreCommandRouter::initPlayerControls
Aug 26 17:07:02 volumiolounge volumio[1251]: info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
Aug 26 17:07:02 volumiolounge volumio[1251]: info: CoreCommandRouter::executeOnPlugin: alsa_controller , getAlsaCards
Aug 26 17:07:02 volumiolounge volumio[1251]: info: BOOT COMPLETED
Aug 26 17:07:02 volumiolounge volumio[1251]: info: CoreCommandRouter::executeOnPlugin: system , getConfigParam
Aug 26 17:07:02 volumiolounge volumio[1251]: Express server listening on port 3000
Aug 26 17:07:02 volumiolounge volumio[1251]: Volumio Calling Home
Aug 26 17:07:02 volumiolounge kernel: pcm512x 1-004c: No SCLK, using BCLK: -2
Aug 26 17:07:02 volumiolounge volumio[1251]: info: [1503767222508] CoreStateMachine::resetVolumioState
Aug 26 17:07:02 volumiolounge volumio[1251]: info: [1503767222512] CoreStateMachine::getcurrentVolume
Aug 26 17:07:02 volumiolounge volumio[1251]: info: CoreCommandRouter::volumioRetrievevolume
Aug 26 17:07:02 volumiolounge volumio[1251]: info: [1503767222581] CoreStateMachine::updateTrackBlock
Aug 26 17:07:02 volumiolounge volumio[1251]: info: [1503767222585] CorePlayQueue::getTrackBlock
Aug 26 17:07:02 volumiolounge volumio[1251]: info: Cannot mount NAS Diskstation at system boot, trial number 2 ,retrying in 5 seconds
Aug 26 17:07:02 volumiolounge volumio[1251]: info: Data script executed
Aug 26 17:07:03 volumiolounge volumio[1251]: info: MPD running with PID631 ,establishing connection
Aug 26 17:07:03 volumiolounge volumio[1251]: info: Setting Device type: Raspberry PI
Aug 26 17:07:04 volumiolounge volumio[1251]: info: [1503767224228] VolumeController:: Volume=undefined Mute =undefined
Aug 26 17:07:04 volumiolounge volumio[1251]: info: [1503767224241] CoreStateMachine::pushState
Aug 26 17:07:04 volumiolounge volumio[1251]: info: [1503767224248] CoreStateMachine::getState
Aug 26 17:07:04 volumiolounge volumio[1251]: info: [1503767224253] CorePlayQueue::getTrack 0
Aug 26 17:07:04 volumiolounge volumio[1251]: info: CoreCommandRouter::volumioPushState
Aug 26 17:07:04 volumiolounge volumio[1251]: info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
Aug 26 17:07:04 volumiolounge volumio[1251]: info: [1503767224274] interfaceApi::pushState
Aug 26 17:07:04 volumiolounge volumio[1251]: info: [1503767224277] InterfaceWebUI::pushState
Aug 26 17:07:04 volumiolounge volumio[1251]: info: Volumio called home
Aug 26 17:07:04 volumiolounge volumio[1251]: info: Reloading queue from file
Aug 26 17:07:05 volumiolounge volumio[1251]: info: [1503767225648] CoreStateMachine::setRepeat null single undefined
Aug 26 17:07:05 volumiolounge volumio[1251]: info: [1503767225650] CoreStateMachine::pushState
Aug 26 17:07:05 volumiolounge volumio[1251]: info: [1503767225652] CoreStateMachine::getState
Aug 26 17:07:05 volumiolounge volumio[1251]: info: [1503767225656] CorePlayQueue::getTrack 0
Aug 26 17:07:05 volumiolounge volumio[1251]: info: CoreCommandRouter::volumioPushState
Aug 26 17:07:05 volumiolounge volumio[1251]: info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
Aug 26 17:07:05 volumiolounge volumio[1251]: info: [1503767225668] interfaceApi::pushState
Aug 26 17:07:05 volumiolounge volumio[1251]: info: [1503767225669] InterfaceWebUI::pushState
Aug 26 17:07:05 volumiolounge volumio[1251]: info: [1503767225680] CoreStateMachine::setRandom null
Aug 26 17:07:05 volumiolounge volumio[1251]: info: [1503767225681] CoreStateMachine::pushState
Aug 26 17:07:05 volumiolounge volumio[1251]: info: [1503767225683] CoreStateMachine::getState
Aug 26 17:07:05 volumiolounge volumio[1251]: info: [1503767225685] CorePlayQueue::getTrack 0
Aug 26 17:07:05 volumiolounge volumio[1251]: info: [1503767225694] interfaceApi::pushState
Aug 26 17:07:05 volumiolounge volumio[1251]: info: [1503767225697] InterfaceWebUI::pushState
Aug 26 17:07:05 volumiolounge volumio[1251]: info: Pushing Favourites {"service":"mpd","uri":"","favourite":false}
Aug 26 17:07:05 volumiolounge volumio[1251]: Discovery: adding c6dcd368-eb77-4ed6-aa21-dd94129ed0f6
Aug 26 17:07:05 volumiolounge volumio[1251]: info: mDNS: Found device lauraboombox
Aug 26 17:07:05 volumiolounge sudo[1323]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl restart airplay
Aug 26 17:07:05 volumiolounge sudo[1323]: pam_unix(sudo:session): session opened for user root by (uid=0)
Aug 26 17:07:06 volumiolounge systemd[1]: Stopping ShairportSync AirTunes receiver...
Aug 26 17:07:06 volumiolounge systemd[1]: Starting ShairportSync AirTunes receiver...
Aug 26 17:07:06 volumiolounge systemd[1]: Started ShairportSync AirTunes receiver.
Aug 26 17:07:06 volumiolounge sudo[1323]: pam_unix(sudo:session): session closed for user root
Aug 26 17:07:06 volumiolounge shairport-sync[1329]: Successful Startup
Aug 26 17:07:06 volumiolounge volumio[1251]: Discovery: adding 47d60158-ec28-46da-aec8-6c25ca56783b
Aug 26 17:07:06 volumiolounge volumio[1251]: info: mDNS: Found device Volumiolounge
Aug 26 17:07:06 volumiolounge volumio[1251]: info: [1503767226247] Shairport-Sync Started
Aug 26 17:07:06 volumiolounge volumio[1251]: info: Pushing Favourites {"service":"webradio","uri":"http://streams.fluxfm.de/xjazz/mp3-320/audio/play.m3u","favourite":false}
Aug 26 17:07:06 volumiolounge volumio[1251]: info: CoreCommandRouter::volumioGetState
Aug 26 17:07:06 volumiolounge volumio[1251]: info: [1503767226503] CoreStateMachine::getState
Aug 26 17:07:06 volumiolounge volumio[1251]: info: [1503767226504] CorePlayQueue::getTrack 0
Aug 26 17:07:06 volumiolounge volumio[1251]: [1503767226509] ---------------------------- Client requests Volumio state
Aug 26 17:07:06 volumiolounge volumio[1251]: info: [1503767226514] InterfaceWebUI::pushState
Aug 26 17:07:06 volumiolounge volumio[1251]: info: [1503767226553] ------------------------------ 53ms
Aug 26 17:07:06 volumiolounge sudo[1342]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl start upmpdcli.service
Aug 26 17:07:06 volumiolounge sudo[1342]: pam_unix(sudo:session): session opened for user root by (uid=0)
Aug 26 17:07:06 volumiolounge systemd[1]: Started UPnP Renderer front-end to MPD.
Aug 26 17:07:06 volumiolounge sudo[1342]: pam_unix(sudo:session): session closed for user root
Aug 26 17:07:06 volumiolounge volumio[1251]: info: Upmpdcli Daemon Started
Aug 26 17:07:07 volumiolounge volumio[1251]: info: Cannot mount NAS Diskstation at system boot, trial number 3 ,retrying in 5 seconds
Aug 26 17:07:08 volumiolounge volumio-remote-updater[578]: [2017-08-26 17:07:08] [connect] Successful connection
Aug 26 17:07:08 volumiolounge volumio[1251]: /data/plugins/miscellanea/auto_play/node_modules/node-mpd/src/mpd.js:189
Aug 26 17:07:08 volumiolounge volumio[1251]: if(err) { throw err; }
Aug 26 17:07:08 volumiolounge volumio[1251]: ^
Aug 26 17:07:08 volumiolounge volumio[1251]: Error: Non okay return status: "Title: It's Not OK"
Aug 26 17:07:08 volumiolounge volumio[1251]: at MPD._checkReturn (/data/plugins/miscellanea/auto_play/node_modules/node-mpd/src/mpd.js:353:10)
Aug 26 17:07:08 volumiolounge volumio[1251]: at MPD.<anonymous> (/data/plugins/miscellanea/auto_play/node_modules/node-mpd/src/mpd.js:188:18)
Aug 26 17:07:08 volumiolounge volumio[1251]: at MPD._handleResponse (/data/plugins/miscellanea/auto_play/node_modules/node-mpd/src/mpd.js:450:3)
Aug 26 17:07:08 volumiolounge volumio[1251]: at MPD._onData (/data/plugins/miscellanea/auto_play/node_modules/node-mpd/src/mpd.js:344:10)
Aug 26 17:07:08 volumiolounge volumio[1251]: at emitOne (events.js:101:20)
Aug 26 17:07:08 volumiolounge volumio[1251]: at Socket.emit (events.js:188:7)
Aug 26 17:07:08 volumiolounge volumio[1251]: at readableAddChunk (_stream_readable.js:176:18)
Aug 26 17:07:08 volumiolounge volumio[1251]: at Socket.Readable.push (_stream_readable.js:134:10)
Aug 26 17:07:08 volumiolounge volumio[1251]: at TCP.onread (net.js:547:20)
Aug 26 17:07:08 volumiolounge volumio-remote-updater[578]: [2017-08-26 17:07:08] [info] asio async_read_at_least error: system:104 (Connection reset by peer)
Aug 26 17:07:08 volumiolounge systemd[1]: volumio.service: main process exited, code=exited, status=1/FAILURE
Aug 26 17:07:08 volumiolounge volumio-remote-updater[578]: [2017-08-26 17:07:08] [error] handle_read_http_response error: websocketpp.transport:2 (Underlying Transport Error)
Aug 26 17:07:08 volumiolounge volumio-remote-updater[578]: [2017-08-26 17:07:08] [info] Error getting remote endpoint: system:107 (Transport endpoint is not connected)
Aug 26 17:07:08 volumiolounge systemd[1]: Unit volumio.service entered failed state.
Aug 26 17:07:08 volumiolounge systemd[1]: Starting dynamicswap.service...
Aug 26 17:07:08 volumiolounge systemd[1]: Started dynamicswap.service.
Aug 26 17:07:09 volumiolounge systemd[1]: volumio.service holdoff time over, scheduling restart.
Aug 26 17:07:09 volumiolounge systemd[1]: Starting dynamicswap.service...
Aug 26 17:07:09 volumiolounge systemd[1]: Started dynamicswap.service.
Aug 26 17:07:09 volumiolounge systemd[1]: Stopping Volumio Backend Module...
Aug 26 17:07:09 volumiolounge systemd[1]: Starting Volumio Backend Module...
Aug 26 17:07:09 volumiolounge systemd[1]: Started Volumio Backend Module.
I tried different SD card but the problem still occurs. Access to my NAS was never a problem before…
Is there a way to start volumio without mounting the NAS on boot routine via ssh?
I found one more failure in the log file. Please see attachment.
Could you please send the portion of the logs that came before?
This is not a volumio problem, but rather an issue with the auto play plugin, please contact the developer
Thanks, looks like you are right! I deleted the autostart plugin folder via ssh from the sd card and volumio starts again.
I try to find and contact the developer the next days.
Hi Plusline,
I’m the developer of the plugin.
Sometimes, mpd has a problem with certain mp3 files. To be honest, I don’t know why that happens and I’m unable to reproduce that on my machines. It was the same for two others using my plugin. You can find more about their fixes here:
github.com/volumio/Volumio2-UI/ … -283342609
github.com/volumio/volumio-plugins/issues/85
Please tell if that helps.
Regards,
Thomas
Hello Thomas,
unfortunately i did not found a solution, jet.
As long I use the autoplay plugin without NAS mount, everyting works fine. When I mount the NAS, Volumio stucks in endless Bootloops…
I tested this on different Raspberries (mark 2 and mark 3) and different SD Cards on official Volumio release and current Volumio Beta version - all the same…
Regards
Plus
thomas.doerr:
