Good morning!
I have a new Pi4 with an IQaudio pi-digiamp+ hat. I have set up the software with Pinn-lite, so I can use it with Volumio, LibreELEC and Raspbian without having to swap sd cards. I set it up without any problems. All of the operating systems are working fine. This is as of 02.12.2019.
Once logged into the Volumio, I completed the initial configuration and was able to get my music to play. After which, I browsed to the settings section and I saw that there was an update available and updated it (the version release date is 01.12.2019). However, Volumio will no longer boot now. I get the following error message:
modprobe: can’t change directory to ‘4.19.79-v71+’ : no such file or directory.
After, which the problem cascades as the script keeps encountering errors due to not being able to locate the correct directory. I’m assuming this is because I’m using Pinn and it has loaded Volumio onto a partition and the script doesn’t know where to find it. How do I edit the boot script to fix this? I’m also wondering why the initial version that Pinn installed works, and this update breaks it?
