Hallo!
df -h reports…
dev/mmcblk0p1 61M 58M 2.3M 97% /boot
Therefore I can‘t make an upgrade to the newest version.
How can I entlarge the boot partition? Or can I delete files from /boot?
ls -la /boot reports …
total 58700
drwxrwxrwx 4 root root 3584 Jan 1 1970 .
drwxrwxrwx 1 root root 4096 Jan 1 1970 …
-rw-rw-rw- 1 root root 41 Oct 18 16:04 .firmware_revision
-rw-rw-rw- 1 root root 41 Oct 18 16:04 .firmware_revision_kernel
drwxrwxrwx 2 root root 512 Jan 1 1980 System Volume Information
-rw-rw-rw- 1 root root 24201 Oct 18 16:04 bcm2708-rpi-b-plus.dtb
-rw-rw-rw- 1 root root 23938 Oct 18 16:04 bcm2708-rpi-b.dtb
-rw-rw-rw- 1 root root 23719 Oct 18 16:04 bcm2708-rpi-cm.dtb
-rw-rw-rw- 1 root root 24379 Oct 18 16:04 bcm2708-rpi-zero-w.dtb
-rw-rw-rw- 1 root root 23643 Oct 18 16:04 bcm2708-rpi-zero.dtb
-rw-rw-rw- 1 root root 25265 Oct 18 16:04 bcm2709-rpi-2-b.dtb
-rw-rw-rw- 1 root root 25394 Oct 18 16:04 bcm2710-rpi-2-b.dtb
-rw-rw-rw- 1 root root 27054 Oct 18 16:04 bcm2710-rpi-3-b-plus.dtb
-rw-rw-rw- 1 root root 26435 Oct 18 16:04 bcm2710-rpi-3-b.dtb
-rw-rw-rw- 1 root root 25249 Oct 18 16:04 bcm2710-rpi-cm3.dtb
-rw-rw-rw- 1 root root 40531 Oct 18 16:04 bcm2711-rpi-4-b.dtb
-rw-rw-rw- 1 root root 52304 Oct 18 16:04 bootcode.bin
-rw-rw-rw- 1 root root 334 Oct 18 16:05 cmdline.txt
-rw-rw-rw- 1 root root 224 Jan 1 1980 config.txt
-rw-rw-rw- 1 root root 6737 Oct 18 16:04 fixup.dat
-rw-rw-rw- 1 root root 6169 Oct 18 16:04 fixup4.dat
-rw-rw-rw- 1 root root 3071 Oct 18 16:04 fixup4cd.dat
-rw-rw-rw- 1 root root 9165 Oct 18 16:04 fixup4db.dat
-rw-rw-rw- 1 root root 9163 Oct 18 16:04 fixup4x.dat
-rw-rw-rw- 1 root root 2654 Oct 18 16:04 fixup_cd.dat
-rw-rw-rw- 1 root root 9811 Oct 18 16:04 fixup_db.dat
-rw-rw-rw- 1 root root 9811 Oct 18 16:04 fixup_x.dat
-rw-rw-rw- 1 root root 5029712 Oct 18 16:04 kernel.img
-rw-rw-rw- 1 root root 5312792 Oct 18 16:04 kernel7.img
-rw-rw-rw- 1 root root 5629808 Oct 18 16:04 kernel7l.img
drwxrwxrwx 2 root root 15360 Jan 1 1980 overlays
-rw-rw-rw- 1 root root 0 Oct 19 19:49 ssh
-rw-rw-rw- 1 root root 2878980 Oct 18 16:04 start.elf
-rw-rw-rw- 1 root root 2770692 Oct 18 16:04 start4.elf
-rw-rw-rw- 1 root root 771904 Oct 18 16:04 start4cd.elf
-rw-rw-rw- 1 root root 4578120 Oct 18 16:04 start4db.elf
-rw-rw-rw- 1 root root 3532328 Oct 18 16:04 start4x.elf
-rw-rw-rw- 1 root root 686628 Oct 18 16:04 start_cd.elf
-rw-rw-rw- 1 root root 4855720 Oct 18 16:04 start_db.elf
-rw-rw-rw- 1 root root 3793224 Oct 18 16:04 start_x.elf
-rw-rw-rw- 1 root root 19831709 Oct 18 16:09 volumio.initrd
volumio@volumio:~$
Cheers,
Thomas
