Hello folks,
im using volumio in my office and because wie do not have a proper wifi, my Volumio on a Raspberry 3 is hooked up to a Fritz WIfi Repeater. Hence, I need a possibility to delay its boot up, becuase otherwise he wont connect up to the network.
Is there a possibility to do so? Maybe with editing a config.txt?
Greetings
hundsboog
Update:
Found something maybe helpful in the volumio manual volumio.github.io/docs/User_Man … tions.html :
So, when I add the line
boot_delay=30
in userconfig.txt - which is the only line - I should get to what I wanted?
