Hello.
Is possible connect a Bluray player into a Volumio Primo via USB?. I want listen the Bluray’s films and concerts through the RCA connections of my analog amp using the excellent DAC of Volumio Primo.
Thanks and Regards.
Hello.
Thanks and Regards.
@DED can you look at this…
Should be theorically possible (assuming your Blu-ray USB works as output and not, as usual, such input for HDD, key, etc… :-/)
I’m more confident with another hint.
Only if you are Superstar user, you can connect an analog/digital audio interface by USB.
You can go out from Toslink/Coaxial Blu-ray player , go in audio board, stay digital on USB and convert finally with Primo DAC.
Hope to be helpful
Regards
Davide
Volumio tech support
