Hi
i have the latest release of Volumio installed on a X68 PC. It works nearly perfect. Now i have one question: is it possible to add Bluetooth support for use with my smartphone (streaming)? I found an older howto but it is for raspberry.
Anyone here who has it running?
Volumio is not (yet) designed to be used as a bluetooth sink. But search the forum : volumio-bluez-alsa-a2dp-bluetooth-support-t6130.html
Hi. Thanks for the advice. Forn now i helped myself by using moode audio. This works nearly ootb for me.
