Can you add a option to connect a Bluetooth speaker.
I found a howto for musicbox. I test it and it works.
discuss.mopidy.com/t/howto-conn … ooth/697/6
Anton
Anton
+1
would be very cool feature - also in use with Amazone Echo or Dot
And for Android users the only way to play all content from the Phone or apps to Volumio!
very good idea, it would help using it with an android phone.
thx
