So i install volumio on the pi3, install the plugin, reboot, then enable: Black screen, nothing else. .
Can anyone help me please?
You don’t specify which screen you have, but have you looked at this link here volumio.org/raspberry-pi-displa … ic-player/
SOLVED
thanks for reply, its the official 7" screen
What i found out is i need to install everything, THEN install the screen…
