Chrome exactly.
that should be good, most of it is build on that browser ā¦
So Iām getting confused regarding the upper answers. Should be the bitrate info displayed on the āplaying nowā screen at least for local files or itās still not implemented? And does it show the dynamic bitrate, or just some static, i.e. what should be read out from the pre-coded track meta data?
does it show the dynamic bitrate.
no, if it does like in radio⦠its static
id3 tags contain data of the songs , but this isnāt used in volumio
So than where does the bitrate info come from, if itās not dynamic read-out and nor from the id tag?
i really dont know im just a user like you.
Ok, but is the bitrate of the track anytime, anywhere, anyhow showed up for you in the GUI with local file playback? (So radios doesnāt count).
if its there you can see it in ip/dev but sometimes its empty then it canāt.
āsamplerateā:"44.1 kHzā,ābitdepthā:ā24 bitā,āchannelsā:2,ābitrateā:ā128 Kbpsā
Also good to know, but Iām still talking and asking about the GUI, not the ip/dev request method.
all that is in ip/dev can be shown in a GUI
So the GUI for you can also display the bitrate? So the next thing is to figure, how and from what is the bitrate info is being read fromā¦
i use it from info i can pull combined in the ip/dev i pull it from the rest api to use it in a rainmeter skin
Sorry, but itās too complicated what you have just written form me. Please letās try to focus on the questions and keep it simple and understandable as it could be for a Volumio newbie (like me)ā¦
its a part of volumio where you can pull the info provided
iām not a programmer so i understand what your getting at learned somethings in time.
Still donāt have clue what you have talked about.
i understand that het you can see how rest api works. with getstate command you can get it.
https://volumio.github.io/docs/API/REST_API.html
in the example there you see there is no bitrate included so i cant pull bitrate on that song.
I understand now the API part of it, but thatās totally not what I have asked for. I want to get the bitrate displayed in the GUI as itās expected. Hereās an example: Link
Thoā so far I have only found images on the web showing that itās playing songs from Spotify that has the bitrate info displayed. All in the other cases (like in me too with local file playback) thereās the sample rate displayed rather than the bitrate.
Ok, so now from the lack of any new answers or info, I must conclude that the Volumio never had displayed the bitrate in the GUI in the cases I have asked about (so with local file playback). I guess I have (somehow) misunderstand the statements in the previous posts of this thread, which lead me here to complain about it. (Still would be a good and useful feature to implement it finally, I like to see and know this information displayed constantlyā¦)
Can we be so lucky that this feature can be seen in the new great release of Volumio 3
Available with web radio, but could be so great to have this with everthing streamed with Volumio
