nope, it’s stick between 570 and 605. Mor then acceptable for 15 euro’s.
Currently flashing the same image to a 12 year old SSD taken form a dell E4200, let’s what that brings.
Hi dev! Sorry for noob question, I’m newbie.
Sorry bjt I couldn’t follow this,
1st i mount my 32gb sd card on my pc and flashed a utility misc ( usb boot) using raspberry pi imager.
-unplug then mount to raspberry pi 4 b.
It showing a green screen on my tft touch screen.
So i waited about 30mins.
Then unplug sd card and follow mount my usb stick that has prototype volumio images in it.
And my screen shows like this.
Sorry dev,
So first, i will flash my sd card as boot usb?
Then plug in to my raspberry pi 4?
And then i do follow what is says here? sudo apt update
sudo apt full-upgrade
sudo reboot
Check current running version of bootloader EEPROM image.
vcgencmd bootloader_version
USB booting was supported starting with version 9-03-2020. You should see that version 16-02-2024 or later is installed. Now check to see if there is an update available.
First you will need to use latest Rasbian image flashed to SD card and prepare your device.
Once the preparation is completed, you can flash Volumio OS to your USB stick and merry you go .
Latest eeprom for raspberry Pi 4 is 2024/01/22. From picture, you can read that yours is 2023/01/11 which is from default channel, not latest. Ensure that you have followed preparation steps, without skipping parts.
Describe how are you flashing your USB stick step by step please.
Is it possible to integrate search and do firmware updates in in Volumio system settings just like you search and do Volumio system updates? It would do things much easier.
Maybe a silly question?
Hi dev! Here’s what happen after do all these instructions.
Freshly flashed new version of raspberry pi os 64bit. Then mount to rpi and start to boot.
On a ssh I’d do all instructions and double check the bootloader ver. It’s up to date.
Then after reboot i unmount the sd card and plug the usb stick with volumio os (latest).
Then here’s what shown on my screen.
