I am looking for suggestions on how to approach the replacement of a mac mini + Roon digital source. In addition, I am looking also for a DAC with volume control, and certain inputs as this DAC must convert a 1TB Aiff library stored on a HDD with USB standard connector (non-C), and must convert audio content arriving from a TosLink cable.
At first I thought Volumio Preciso matches my case, but that implies I have to continue using the mac mini and Roon as music server.
what are your suggestions?
ps I also have a Qobuz subscription license for music streaming.
pps not that I am tired of Roon. Actually I’m very happy with it and one of the lucky guys having a perpetual license of Roon since their startup. But I’m tired with the mac mini as a source as it’s always a computer with all mixups and glitches that come along with it
thanks in advance to all constructive contributors
VS
so how do I solve the problem of the AIFF files? does the volumio DAC not support the .aiff format? what alternatives would I have?
and second question: do I interact with my music library with Roon or with the Volumio app?
(select album, import music, playback/pause etc)
A DAC does nothing more then converting a digital stream to an analog signal.
Volumio (the OS/Application) takes care of you AIFF files, so that solves your “problem”
So Volumio users, how do you manage / interact with your music library? which app do you use in case you have also Roon? Or if you prefer in other words: can Volumio App replace completely Roon?
