Volumio Information
Volumio Version: volumio-2.873-2021-02-19-pi.img
Hardware: Raspberry Pi 3 Model B+
DAC: Topping D10s
Hi together
Volumio doesn’t support Amazon Music HD. I’m looking to combine it with Volumio: on the same (Raspberry) device would have liked install Volumio with another system which gives i.e. Firefox to connect to Amazon Music HD, attached via Topping 10s DAC to my active loudspeakers.
To add on berryboot I was able to create a corresponding Squashfs of Volumio’s Raspberry image on Ubuntu 20.04, obviously with no error as you may see below:
george@george-NUC8i5BEH:~/Schreibtisch/Berryconv/BerryConverter-master$ chmod 755 berryboot_conv.sh
george@george-NUC8i5BEH:~/Schreibtisch/Berryconv/BerryConverter-master$ ./berryboot_conv.sh volumio-2.873-2021-02-19-pi.img volumio-2.873-2021-02-19-piB.img
[sudo] Passwort für george:
sed: /mnt/etc/fstab kann nicht gelesen werden: Datei oder Verzeichnis nicht gefunden
Parallel mksquashfs: Using 8 processors
Creating 4.0 filesystem on volumio-2.873-2021-02-19-piB.img, block size 131072.
[=============================================================|] 2720/2720 100%
Exportable Squashfs 4.0 filesystem, lzo compressed, data block size 131072
compressed data, compressed metadata, compressed fragments,
compressed xattrs, compressed ids
duplicates are removed
Filesystem size 344489.75 Kbytes (336.42 Mbytes)
99.01% of uncompressed filesystem size (347947.12 Kbytes)
Inode table size 2705 bytes (2.64 Kbytes)
24.57% of uncompressed inode table size (11008 bytes)
Directory table size 76 bytes (0.07 Kbytes)
95.00% of uncompressed directory table size (80 bytes)
Number of duplicate files found 0
Number of inodes 4
Number of files 2
Number of fragments 1
Number of symbolic links 0
Number of device nodes 0
Number of fifo nodes 0
Number of socket nodes 0
Number of directories 2
Number of ids (unique uids + gids) 1
Number of uids 1
root (0)
Number of gids 1
root (0)
Booting up, there is an error:
unable to locate or execute sbin/init user/lib/systemend/systemend /init inside volumio-2.873-2021-02-19-piB.img (...B=name of the converted file).
Is there any help possible, hopefully not too complicated, because I am an old man with only user knowledge of Ubuntu?
Hoping to hear from you is
GEORGE
