I’ve got a Raspberry Pi in hand and I’m about to get a Beaglebone Black. I have other projects I can user either for. What are the pros/cons of each. Is one of them better with volumio? Point me to existing comparisons if you can.
I’m leaning toward the Beaglebone Black (BBB) for volumio.
My target audio is this:
XMOS 384kHz high-quality USB to I2S
DAC-24192 SABRE 24/192 DAC
If I understand this, the BBB USB could be dedicated to the XMOS USB.
I will fine using a serial and ssh console for admin work.
I also assume this would be a supported audio interface.
Yes is supported, and I use it with extreme satisfaction…
