Here is a script to convert Volumio playlists to Windows m3u8 ones.
One only needs to copy the code below in a text file, give it a name.sh, make it executable and run it with ./script_name.sh. That’s all.
Assumptions:
- the Windows folders structure of one’s music collection will be the same of the Volumio’s one. Example, the hard disk connected to your RPI will be a backup of the Windows’ one (or else you might tweak it to your different needs)
- one will need only to customize the variables win_path and vol_path after checking the Windows playlists and the path of music folder in Volumio. Don’t delete slashes and backslashes here!
- Converted playlists will be m3u8, same as those made with Foobar2000. These format supports UTF-8
- the to be converted playlists will be copied in a subdirectory of the one you are running the script from. It is called “vlpllist” and that’s where you’ll find the converted ones too
#!/bin/bash
# Set your Windows PC music folder path (don't touch slashes).
# Example:
win_path='E:\\Data\\Music\\'
# Set your Volumio music folder path (don't touch slashes and back-slashes).
# Example:
vol_path='USB\/drive_label\/Data\/Music\/'
# Copy all Volumio playlists to a "volpllist" subfolder
mkdir volpllist
rsync -av --exclude=".*" /data/playlist/ volpllist
cd volpllist
# Rename playlists to *.m3u8
find . -type f ! -name "*.*" -exec mv {} {}.m3u8 \;
# Crop leading "[" and trailing "]"
sed -i '1s/^.//;s/.$//' *.m3u8
# Insert a break-line after each },
sed -i 's/},/&\n/g' *.m3u8
# Replace Volumio music folder with Windows music folder path
sed -i "s%$vol_path%$win_path%g" *.m3u8
# Replace remaining / with \
sed -i 's/\//\\/g' *.m3u8
# Crop leading {"service":"mpd","uri":"
sed -i 's/{"service":"mpd","uri":"//g' *.m3u8
# Crop trailing text starting from first "
sed -i 's|","title":".*||' *.m3u8
# Add a leading blank line
sed -s -i '1i\\' *.m3u8
# Add a leading "#" in the blank line
sed -i '1s/^/# /' *.m3u8
# Add BOM (be careful when a file already has a BOM)
sed -i '1s/^/\xef\xbb\xbf/' *.m3u8
# Convert Unix LF To Windows CRLF
sed -i 's/$/\r/' *.m3u8
# Go one level up
cd ..
