hello everyone,
i am back from other pastures and want to give Volumio another try.
installed ok but have several startup questions:
my system is RPi 3+ with allo digione and 7" hdmi touch screen.
question 1)
the boot is stuck on a login prompt. how do i bypass this?
q2)
have installed spotify, connect2 and squeezelite.
but where is javalite?
q3)
allo digione sounds great playing music off local LMS.
spotify app does see the Volumio device but when played, there is no sound and
local music continues to play.
is there a basic conflict with squeezelite and other sources?
q4)
once i get past the boot login bypass,
will LXDE appear?
thanks for your help…
