Autostart plugin, track 3 always starts
Hi, I installed Volumio on Raspberry Pi4 model b recently updated to v. 3.757.
When Volumio is started, the “Autostart” plugin starts track 3 of the disc I was listening to, regardless of the disc, track 3 always starts. However, if I listen to a web radio, it never starts again when I restart it.
Does anyone have any suggestions for fixing the problem? Thank you
I also have difficulty with this plugin by switching to Volumio 3. On startup it selects the last folder or radio station that was playing, but as the cursor advances the sound remains muted.To turn on listening I have to stop playback and select the song or station I should be listening to. At this point everything returns to normal, but it is not an automatic startup.
I think I have solved my problem. By assigning in the configuration “Delay before music starts” a value of 35000 msec and setting ON “Play from last position,” the plugin now works properly.
For lower values of delay it does not work at all. Volumio runs on an RPi 3 with SD card.
With Volumio in the previous version I was using the default values without any problems.
