"Autostart" playlist after power on?
is it possible to automatically start a playlist (the last playlist) when the Volumio device started after a power on?
Background: I have my workshop all powered down when absent, so my Raspberry Pi have to boot when power is restored and a playlist have to be started afterwards. So as workaround my home automation system pings the device and when there is a respond a “cmd=play” is sent. Is there a more elegant solution?
TIA!
Roland
(Graz, Austria)
Did you take a look at the plugin Autostart?
Thanks gor your quick respond, didn’t realize the possibility of plugins…
I will check this out!
Roland
