Autostart - It Doesn't
Hi All,
Am I missing something here? I built a queue list of web radios, installed the AutoStart plugin which I enabled, and enabled the ‘Play From Last Position’ option.
After a reboot…nothing. I had to press my play/pause button to get things rolling. A different problem was then identified - the ‘Next’ and ‘Previous’ buttons only work if I pause the currently playing radio first??
This behaviour is only happening with web radio. I don’t have any locally stored music on this particular system, instead I can connect to my NAS. Queues built from those files work as expected via my buttons, I haven’t tried the autostart plugin with those, as this system is only for web radio.
Any ideas why web radio is behaving differently to music files?
Regards,
Ste
