Not sure if this was ever asked before, but I can’t seem to find an answer to wether this is possible or not:
I’m using multiple Raspberries with Volumio (up to 14) in a professional environment for playing music which are provided via USB Drives. Is it possible to just have Volumio play the contents of a connected drive or folder on that drive, withouth having to build a new playlist everytime?
Eventually they should all play from the same NAS - but even then I would like them to play the content of a certain folder on that NAS, so that I can just change the music in that folder, maybe reboot the Raspberries and have them all play the new content.
Bonus question: Would it be possible, via some scripting, to have Volumio automatically play from a USB drive as soon as it connects? For example, if I play a Webradio Stream on it for most of the time, but want it to play a selection of songs for a while which I have on a Drive, I’d like to be able to just pop in that drive and have Volumio just play its content, and after disconnecting continue playing the stream (not sure if that’s possible but would be great!).
Thanks in advance, any answer will be appreciated!
