Is there an easy (non-ssh) way to reboot either volumio or the pi every Sunday? Like a plug in maybe?
Thx
Thx
you can create a cron for it.
sudo apt-get update
sudo apt-get install cron
Create a bash file that will take care of the reboot:
nano /home/volumio/restart.sh
Add:
#!/bin/bash
sudo reboot
CTRL+o + CTRL+x
chmod 755 /home/volumio/restart.sh
crontab -e
Add:
0 23 * * 0 root /home/volumio/restart.sh
CTRL+o + CTRL+x
Thanks Wheaten
I had done that on Volumio 2 but that got wiped when I updated to 3 and I didn’t remember how to do it.
0 4 * * * will run that script every day at 4am, correct?
Nonetheless, given that volumio isn’t the most stable platform and that regular restarts are probably a good idea, I would still advocate for a more user-friendly version of this.
yep. will do the reboot at 04:00
I just noticed that my volumio is not rebooting as supposed to.
my crontab file reads: 0 4 * * * root /home/volumio/restart.sh
when I execute /home/volumio/restart.sh manually, volumio does indeed reboot.
So it seems that it’s simply the cronjob that isn’t being executed.
Any suggestions?
you can try this as cron job. You don’t need the script.
0 4 * * 0 /sbin/shutdown -r
Thank you. I ended up putting the instruction in the system-wide cron tab (/etc/crontab), and now it works.
Yep, works great!!
volumio@volumio:~$ crontab -e
-bash: crontab: command not found
volumio@volumio:~$ sudo su
[sudo] password for volumio:
bash-5.0# crontab -e
bash-5.0#
Hmmm…
“One image is worth a thousand words”
