Audiophonics Sabre ES9023 I2S DAC
Hi ev’rybody.
Just a quick post to share I received today the Audiophonics Sabre ES9023 I2S DAC:
audiophonics.fr/audiophonics … -8396.html
I tried it and it sounds great
Here it is in a very messy setup along with an Adafruit LCD display.
Nice setup!!, I am waiting for over a month now for a restock (and a listing on their ebay page) looks like a great DAC.
Was the the display plug and play or did you have to edit some config files/use special distribution?
Hi!
The display is a kit from Adafruit industries:
http://www.adafruit.com/products/1110
It requires a little soldering, but it’s very fun to build.
As for the software, I wrote my own implementation and I will soon post the source code.
In the meantime, check the work of the wise cyber7, easy to install and ready to use:
http://volumio.org/forum/raspberry-and-adafruit-lcdplate-t531.html
Regards,
Thanks,
I will take a look!
Hello, I juste received mine, but doesn’t work !!
Could you post the linked setup
I have connected +5V, GND, DATA, LRCK and BCK to P1-12, P1-06 P5-06, P5-04, P5-03
Is it OK ?
See this thread to check: http://volumio.org/forum/ess9023-with-t582.html
You have enabled I2S in Volumio haven’t you? The Hifiberry setting works with my ES9023.
