Hi all,
A short message to report a bug.
I have following config :
Volumio 2
Raspberry 3
Hifiberry Digi
When I restart the raspberry, I have no music as audio jack is putted as output device automatically.
I change manually to hifiberry and sound is coming back.
Are you facing the same issue?
Any ideas?
Many thanks.
It solved the problem of audio jack and as well nas mounting issue after a reboot.
I have noticed following remaining pbs:
- wifi connection is sometimes lost when playback is paused since a long time.
- some sound break when reading a file from the nas. ( I have no pbs for reading audio files from other devices)
Regards,
Vincent
