Hy I want to hear a Audio CD with my Raspberry Pi 3 with Volumio v3198 but the cd player search and search but nothing is happening. I had 3 cards flashed with 3 different images. ( 3.197/3.226) It’s the same problem.2.917 it’s Working. Sorry for my English.
Hello, I’ve tried everything again. I can rule out power problems. CD playback with v. 2917 works without problems. But v3.198 SEARCHES AND SEARCHES The player but nothing Happens. Hope someone can help me. thank you
This helps me:
When installation NanoSound CD on volumio version 2.882 or later,
there is a bug which prevent a successful installation. Fortunately, there is a work around:
If you haven’t ready done so, go to http://volumio.local/dev and click ENABLE under SSH
Enable SSH under volumio
Method 1: Edit sources.list manually
Using a terminal software such as Putty, SSH into volumio.local,
default user name and password are both “volumio”
SSH into volumio
add temporary the debian stretch source to install the dependecies
remove the line again from source from sources.list
Method 2: Run Script
Make sure NanoSound CD is not installed
Using putty or terminal in mac, ssh to volumio.local
o eg. in terminal in mac , run:
o ssh volumio@volumio.local
o when asked about continue connecting type: “yes“
o Enter password: “volumio“
install unzip and dos2unix
o sudo apt-get install unzip
o sudo apt-get install dos2unix
unzip the file
o unzip dxLoHCHS6zbt8HGZGoyELmLacvo.zip
Above will unzip a file called Workaround_BuildEssentials.sh, Make it executable
o chmod +x Workaround_BuildEssentials.sh
o dos2unix Workaround_BuildEssentials.sh
Run it
o ./Workaround_BuildEssentials.sh
Install NanoSound CD from repository
Alternatively, you may also use the previous version of volumio which do not require above workaround.
Bluetooth playback music not sincron with cover and CD player playback STILL NOT working. NO button available Please fix these bugs now. Stay with version 2.917 for now. Thanks
