I would like to see that you can turn off artist info in the now playing screen.
Use classic or Contemporary instead on Manifest UI.
I like the layout from Manifest, only not the artist info
if you are using a connected hdmi display to the rpi you can try the now playing plugin.
yes thx got it working Had to change some settings in the plugin. So this request is not actual anymore. By the way i am running from minpc now (x86)
Yeah, lost track with you ![]()
