I’m Vash, a firmware engineer from Italy. I’ve been working on a project called Arte&Luce and I’d love to share it here, since Volumio is where it lives.
What you’re seeing: LED bars playing a light show for Apparat’s album “A Hum Of Maybe”. It’s not a sound-to-light effect reacting to the volume. Each track has its own light direction, created in advance from the music and played back in sync with the audio, frame by frame. You put on a record and the room becomes part of it.
On the Volumio side, the player runs as a plugin on a Raspberry Pi 4. It follows playback (play, pause, seek, track changes, gapless) and drives the lights over their own Wi-Fi. It’s still a prototype with one album, but it works.
I’m curious how you’d see something like this:
Which album would you want to experience this way first?
Would it feel different if the light direction came from the artist themselves, or from a light designer, rather than being generated?
Do you see it more as part of your hi-fi setup, or more like a special edition, the way some people collect a beautiful vinyl pressing?
This is truly amazing and totally different from the lighting projects I saw until now. What is special is that it somehow captures the emotional content of the track and delivers it visually.
This sounds really intresting! Is the light sequence generated automatically for each track or is it made ad hoc? I would love to understand how it works and how you are supposed to use it, since, as you said, the light direction is created in advance.
@FOXY_2003 thanks! Perfect timing: I’ve just published a new one, the first track from a second album, Dardust’s “Urban Impressionism”.
Dardust was a real challenge: no vocals, so the piano had to become the protagonist (the centre bar now plays like a keyboard), and a pulsing bass that could easily have turned into flashes everywhere.
To answer your question: it’s a mix, and more crafted than it might look. The software analyses the track (instruments, beat, sections, single piano notes), but that’s just the raw material. Each album gets its own engine, designed by studying the music and the artist’s language. Then every track gets its own direction, built through many iterations: frame-by-frame simulations, tests on the real bars, filming and measuring the sync, then adjusting until the light says what the song says.
Once a show is ready, you just play the music in Volumio: the lights follow playback and stay in sync.
It’s not available yet because I’m trying to understand how much interest there is. If people like the idea, I’d love to keep working on it and turn it into a real product.
So any feedback, like this one, really helps!
For me the light show is just a bit too dominant for my tasting and I am sure I need to find a different place to live, if i place it in our Livingroom.
However it could be a nice addition for deaf people. Light and sound pressure to feel/see the emotion of music.
But it catches emotion well and as someone said before, I can’t recall seeing this in this way.
@Wheaten Thank you, this is genuinely useful feedback.
You’re right: what works as a show can be a lot for a living room. So the player now has a Living room mode next to the full Show mode. It’s the same show with the same timing, just toned down for everyday viewing: lower light, softer full white, slightly calmer colours. The hits and light changes are still there, because that’s where the emotion is, they just hit less hard.
There’s also a separate photosensitivity protection that softens rapid flashes above 3 per second, and it’s always on in Living room mode:
Your point about deaf people really stayed with us. We don’t have an answer yet, but accessibility in the broadest sense matters to us. We’d love to explore it properly, ideally with people from the deaf community, combining light with physical vibration as you suggest.
Thanks for opening that door.
So the show is supposed to be made for each track and if available it would just play automatically if you have the hardware and everything set up correctly.
I wish you luck with your project then, I’ll wait for more updates!
Thanks, not yet! It’s not in the plugin store because it’s still a prototype living in my living room, with one album.
The plugin is only one piece of the puzzle: the light shows are prepared in advance for each track, and it drives a dedicated set of LED bars over their own network. So getting from “works at my place” to “install it and enjoy” is a real step.
I’ll be honest: seeing people ask for it makes me really happy. This project started as a personal obsession and it’s slowly becoming a dream: turning it into something anyone can have at home. Comments like yours are exactly what tells me whether it’s worth taking that next step.
If you’d like to stay in the loop, just let me know and I’ll keep you posted. And I’d love to hear what your setup looks like and which album you’d want to see first!
Thank you! Yes, you got it exactly: each track has its own show, and when you play it in Volumio the lights simply follow: play, pause, skip, seek, all automatic. You just listen.
There’s indeed a lot of work behind it, and a lot still ahead. My dream is to get it out of my living room and into other people’s homes, so hearing that people would want it really keeps me going.
That’s really cool and impressive. However, I’d also like to point out that this doesn’t really fit with how I usually use Volumio - namely, to listen to music with excellent sound quality so I can relax. In that context, this would actually distract or even bother me.
But anyway, everyone has different tastes, and it’s great to see once again just how open the Volumio platform is and all the things that come out of it.
Very nice. I used to use a xbox 360 has a cd player and then run neon to a hdmi splitter and added a couple of projector that was always fun at a party.
Have you looked in to integrating govee or hue light in to your project?
@Axel that’s a fair point, and I agree with you. The videos I posted use the high-energy tracks on purpose, because that’s where the light can do something that grabs you in a short clip. On calmer tracks the show is much quieter: it only does what the music does.
For everyday listening the plugin also has two softer settings:
Living room mode: the same show at much lower intensity, so it stays in the background.
Accompaniment mode: for tracks without a dedicated show. There’s no show at all, just a slow, soft colour atmosphere that follows the mood and energy of the track. The idea is to help you get into the music, not to pull your eyes away from it. It’s still early and I’m tuning it.
And it can be switched off with one toggle. The music always comes first and the light is optional.
@Plag an Xbox 360 as a CD player with projectors at a party sounds like a lot of fun For now I’m sticking with the three bars. I build them in a specific way (RGBW strips, per-pixel control at 60 fps, diffusers) to get the effect I had in mind: fast hits, notes placed along the bar, and so on. Hue and Govee aren’t integrated yet, but both have open local APIs (Hue Entertainment API, Govee LAN API), so it’s definitely doable. Bulbs and lamps can’t follow single notes the way a strip can, so it would be a simpler version, closer to the accompaniment mode than to the full show. I’d be happy to build an integration with any system that has an open protocol. Honestly, that’s the part I enjoy most.
Thanks again @Axel and @Plag! This is still a prototype, but I really want to keep going with it, and I can’t wait to spend more time on it. I have a lot of ideas: working with artists and light designers on shows made for their own albums, softer modes for everyday listening, and more. The dream is a new way to experience music at home, where the light is part of the record and not just decoration. Feedback like yours helps me figure out what actually matters to listeners, so please keep it coming!
Since you haven’t written much more than “via their own Wi-Fi” regarding how the lights are connected, perhaps you could add a few words about how that works - and, of course, what requirements this entails for the lights. Thx
Fair point, I kept that part short. The light side is deliberately simple and uses standard maker hardware: ESP32-based controllers driving addressable RGBW LED strips, connected over a dedicated Wi-Fi network that the Volumio box provides. Nothing exotic, and no special requirements beyond addressable strips and a compatible controller.
Most of the work happens upstream, offline: analysing the music and building and rendering the light show for each track. Volumio then plays it back in sync with the audio. The longer-term idea is something like audio-visual albums, and right now I’m focused on improving the quality of the whole chain.
