The USB ARCAM DAC is recognized and available in the drop down list.
But when starting to play, The following error message pops up:
Error Failed to open “alsa” [alsa]"; Error opening ALSA device “hw:5,0”; snd_pcm_hw_params() failed.
The log file is: logs.volumio.org/volumio/Hc97WQY.html
I see: error: Cannot set ALSA Volume: Error: Alsa Mixer Error: amixer: Mixer hw:5 load error: Invalid argument
Is this a known issue? What else can I try?
I attached this USB DAC because I was trying to test the BruteFir plugin.
It took me some time to find out that this plugin does not work with the standard audio jack output.
Therefor I attached my ACRAM DAC.
