I just installed a new image of volumio on my pi3b, then ssh’ed into the system and did an update and upgrade. There were dpkg errors during upgrade and after a reboot, mpd no longer works.
I have tried this three times, same result each time.
The output after apt upgrade:
Reading package lists… Done
Building dependency tree
Reading state information… Done
Calculating upgrade… Done
The following packages will be upgraded:
dhcpcd5 e2fslibs e2fsprogs firmware-ralink libblas-common libblas3 libcairo2 libcomerr2 libdrm2 libfreetype6 liblapack3 liborc-0.4-0 libpam-modules libpam-modules-bin libpam-runtime
libpam0g libpango-1.0-0 libpangocairo-1.0-0 libpangoft2-1.0-0 libpixman-1-0 libsdl1.2debian libss2 libva1 x11-common
24 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 6288 kB of archives.
After this operation, 1994 kB of additional disk space will be used.
Do you want to continue? [Y/n]
The last lines of output after upgrade show
dpkg: error procapyessing archive /var/cache/apt/archives/firmware-ralink_1%3a0.43+rpi6_all.deb (–unpack):
trying to overwrite ‘/lib/firmware/rt2661.bin’, which is also in package firmware-misc-nonfree 20161130-4~deb8u1
Preparing to unpack …/libblas-common_3.7.0-1~bpo8+1_armhf.deb …
Unpacking libblas-common (3.7.0-1~bpo8+1) over (1.2.20110419-10) …
Preparing to unpack …/libblas3_3.7.0-1~bpo8+1_armhf.deb …
Unpacking libblas3 (3.7.0-1~bpo8+1) over (1.2.20110419-10) …
Preparing to unpack …/liblapack3_3.7.0-1~bpo8+1_armhf.deb …
Unpacking liblapack3 (3.7.0-1~bpo8+1) over (3.5.0-4) …
Preparing to unpack …/libva1_1.7.3-2_armhf.deb …
Unpacking libva1:armhf (1.7.3-2) over (1.4.1-1) …
Preparing to unpack …/x11-common_1%3a7.7+16_all.deb …
Unpacking x11-common (1:7.7+16) over (1:7.7+7) …
Processing triggers for systemd (215-17+deb8u8) …
Processing triggers for libc-bin (2.19-18+deb8u10) …
Errors were encountered while processing:
Anyone have this issue with the most current image?
Any ideas what is causing the error?
